Roof with one plane on a different plate height **complex roof system**
    I am having trouble figuring out how to put one of my roof planes on a different plate height than the rest. I have attached the front view of the house.
    Thanks in advance for the help
    You can create separate roofs and join them or select the sketch lines and specify an offset from the roof base.
    chad
      chad
        If I do separate roofs and join them I am still having the issue of the roof not looking right or the more likable reason is I do not know how to correctly put the roof on. I just need the front slope above the front door to be the only one at 10' plate and the rest at 9' plate is there are video or screen shots to show how that is done?
        Thanks again
