Cannot open properties window
    Hi..
    I have a problem opening properties window in Revit 2015. It's checked and I tried to uncheck and try again several times.. I even reinstalled the software and tried again ..
    Anyone?
    Is it there and unresponsive or is it totally missing?
    If unresponsive, close Revit and follow this video: https://knowledge.autodesk.com/searc...16eeb6292.html
    If totally missing, try a Save As and close Revit then reopen. Also check your video card drivers.
      Are you sure its not just "docked" in another window?
      You can see the properties panel in the bottom of the project browser in the picture below.
