Is there a way to pin or associate two objects with one another without having to group them? I want them to be able to move together as well. Again, without grouping them.
"pin" two objects together/Associate them without creating a group
Similar to levels, they are associated or 'pinned' to each other so when you move, or in that case, stretch one level, the others stretch as well. The...October 6, 2016, 09:13 PM
I have an apartment building model with unit types as groups. I have two different instances of the group in 2 different locations, both of them have...February 3, 2021, 08:17 PM
I have a group made up of railings (Omega fences) which make up an enclosed exterior area. Included is a shading structure as its own group.
...June 14, 2017, 04:05 PM -
I'm experimenting with groups in an effort to reduce the amount of work in annotating our typical elements.
I've started with a simple...February 12, 2013, 03:16 PM -
Is there a way in Revit to group elements together such that they can be selected as a single element? Currently working on some window details and would...June 19, 2012, 02:59 PM
Monumetric Footer In-screen
