A little Challenge: Symbols and Titleblocks
    This image is from what I created in Revit, I wanted to see if anyone else could do the same. It's on a titleblock, so you can only use tools available to either symbols or titleblock families. I preferred to not use an image or DWG (cause I'm ocd like that). Like I said, I already have this created but want to open for discussion how you guys would go about doing the same. I'll reveal how I did it for those interested but only after a few posts to not dilute the thinking process here.
    Discuss...
    That is a tiny castle.... is it to scale?
    -Alex Cunningham
      You mean this?
        Yes, that's why I put the dims in there. It is a logo for a titleblock.
          Originally posted by gaby424 View Post
          You mean this?
          Are those dims in mm? If so I think you're a little off. 11/16" = 17.4625mm
          The dims are there for a reason. If you want, take the image download it and scale it and use it for reference in your attempts.
            ah... i didn`t thought about dimensions. It was to easy
              You mean this?
              Gaby, did a dragon enter through the door of your castle? What happened to that door? :laugh:
                the dragon wasn`t in scale
                  artistic freedom :thumbsup:
                  -Alex Cunningham
                    I wasn't going to say anything about the door, but it's interesting how 3 lines and a hemicircle turned into a half eaten cupcake!
