virtual visit and modify camera position in Z
    I looking for how to modify a Z position in virtual visit (walk through), but i would like modify just 3 or 4 position camera.
    Example, i have 500/600 pictures at 1.80 meters of first floor and 100/600 pictures at 3.50 meters.
    I hope, you understand what's i say
    Thanks
    Il vaut mieux un qui sait plutôt que dix qui cherchent
    I'm Just simple Architect en France !
    "virtual visit" = "walk through" ? (Assuming Google is right on that one, here´s some short directions)
    • Go to an elevation view, right click the walkthrough in the projectbrowser and choose "show camera"
    • Then pick "edit walkthrough"
    • And set "control" to either "path" or "active camera" > These will let you adjust/move the path and the camera orientation in the Z axis.
      Just put the same reply in French chapter here.
      I would just add that you can adjust the height of the all path by dragging it in the view after "show camera".
      Edit: F8 key helps you when modifying POV
      Julien
      P. DAC
