Keynote Supplementary Text
    Is there a way to have an additional line of descriptive text in a Keynote Material Tag which is not linked to the Keynote file? For instance, can we have the Description parameter linked to the Keynote Tag?
    Thanks!
    I don't think so. Keynote tags are pretty limited to just referencing keynote file information. You might have to create another tag and tag your material twice.
      Nope, but you can use User Keynotes to add all the info you want. You can't crosslink between tags and keynotes (as far as I know)
        Thanks for the responses. This is what I thought, but I wanted to see if there were any workarounds.
