Railings 'Edit Joins' Problems
    Overlapping lines problems on stair railings, have many landings.
    'The Railing line must be a single connected Sketch. If you want separate pieces of Railing, create two or more separate Railings.'
    Is there another way? Thanks..
    Question - How does Revit know which one of your Continuous lines is the Start or End of the Railing?
    The Railing tool needs a Start & End Point to work. That's why it throws up that error
    You need to split your Magenta Line, and leave a gap of say 5mm between your start & end points.
    Give it a try & see what happens
    Dwane
