Region Fill Default
    Region Fill Default
    Hi All.
    How do you go about setting up the default region fill when starting to use the region fill tool?
    Thought it would default to the previous region fill used, like a wall would default to the last wall used...
    This is however not the case! Any ideas on how to set-up the default region fill pattern?
    Thanks,
    Craig
    Building a template?
    Anyway... Best advise would be to not use the filled regions in the first place... They are only for 2D "cheating"
    Hmm... is it Aaron or Cliff who´ll get on my back now... :hide: (Yah, didn´t care to read thru that other thread)
