Phasing detail levels
    I have an existing masonry building which I am selectively demolishing.
    In all of my views with 1/4"=1'-0" or greater I would like for my existing walls to have a diagonal hatch.
    In my views larger than 1/4"=1'-0" I would like to be able to see the actual construction of the wall.
    What is the best way to achieve this? Phasing graphic overrides? Detail levels? Object Styles?
    I´d use view filters for this...
      I would go with View Templates. Create two templates: one with "normal" wall visibility, one with an override set to the wall category.
