Revit 2012 re-load problem
    I'm having a problem re-installing Revit 2012. I recent replaced my over flowing SSD and as such had to do a complete re-install, including other autodesk programs such as AutoCAD 2012. The first time I installed revit 2012 on my new system it failed to load properly, as I was running another program (my bad). Obviously when I went to fire it up it only got as far as the starting window. I was not able to uninstall the program normally and had to do it manually (delete) including going and deleting registry files. Now when I try to reinstall revit its telling me its already installed(?) and so I can't install. Additionally I've uninstalled all autodesk programs off my machine for possible conflict.
    Has anyone else had this problem? I will also contact vendor and autodesk for a soultion.
    Thx.
    Download Windows Cleanup Utility from MS. Install it, run it and delete ONLY the Revit 2012 installer.
    here is a link to another thread on RFO about this
    Mark Balsom
      This is for MS office only. It seems they have discontinued the utility program because it damages other files.
      I tried revo Uninstall to no luck either. Looks like I'm going to have to reinstall windows.
      Thanks anyway.
        It's not only for office, i know it says that, but its not. and no its not discontinued. I have used it on many occasions to solved your issue.
        Also download from here
        Mark Balsom
          OK. I will use next time. Used the sledgehammer and reinstalled. All good.
