Rafter / Truss Selection
    In roof properties there use to be a choice between Truss or Rafter which determined at what point the roof pitched from, inside or outside of frame.
    Can't seem to see it, anybody else ? or am I having a senior moment.
    Mark Balsom
    Did you make the roof with pick by walls?
    -Alex Cunningham
      Yep, senior moment ! Thanks Alex, I was trying to set it before I created the roof. Once created by pick wall it appeared.
      Mark Balsom
        w00t i helped a guru!!!! my life is complete.
        -Alex Cunningham
          OK.. OK.. You caught me at a weak moment, pleeeease don't tell anybody here, its our little secret.
          Mark Balsom
            Dude, you've helpled me before. I'm the biggest Guru here.
            Wait, Guru means noob, right? :laugh:
            Dan
              Who are you again? I cant wait till I have my first senior moment. After I do I am moving to a senior living complex. Its going to be ever so much fun!!!
              -Alex Cunningham
