Divided Surface
    Divided Surface
    I am doing my first curtain panels by pattern, and I am having some problems.
    I need to use the Triangle flat pattern, but I am getting odd results: the orientation is fliiped in a chekered (triangles ) way.
    Half of the panels are oriented to the outside and the other half to the inside.
    Is this normal, and is there a workaround?
    Thanks in advance
    Gonçalo Feio
    Hi Gonçalo. Did you get this sorted? If not, could you provide a screenshot to help clarifying the problem?
      Or better yet, post the project... It's kind of difficult this way to suggest a solution.
      BUT: you might want to look into the border conditions of your Surface. There are a few settings there and I think you might have it set to "full panels" (or whatever they call it).
        EDIT: sorry, double posting. Got a Database Error and then it all got kind of screwy...
          That would be my fault :hide:
