How to adjust beam end conditions
    Would like for my beam end at the wall to be "plumb cut" so meets the wall cleanly. I can miter beams when they are in plane to each other, but cannot adjust the beam end condition at wall. Beam was created loading a default beam structural system family. Using Revit 2017.
    You could just cut it using a referenceplane on the inside of the wall.
    On a sidenote I am guessing that it is a visible beam and if you are gonna attach it on the inside of the wall the bracket will be visible?
      What Iberkim said. Move the boundary line out further till the beam fully extends out then you can cut it. Don't forget to name the reference plan so you don't accidentally delete it. Same thing applies for the ridge as well.
        Thank you this is helpful! Not sure how we will detail the bracket yet.
