Broken Revit File Extension Association
    Somehow my work computer nolonger recognizes RVT files as Revit files. I've tried right clicking and using the "open with this program" buttton and navigating to the Revit exe file. This does not work. I've also tried clicking the "always use the selected program to open this kind of file" box.
    Any ideas?
    Thanks!
    Scott Hopkins AIA LEED AP
    Peikert Group Architects
    Windoze 7
    Open My Computer and in the address bar type
    Control Panel\All Control Panel Items\Default Programs\Set Associations
    XP
    Control Panel > Folder Options > File Types
    With either OS you can change the file association for .rvt files.
    :thumbsup: :beer:
    -Alex Cunningham
      Thanks for the replay Alex. I couldn't get it to work your way, but I did find this on the web that worked for me.
      If a program does not show up in the list, you can make the program a default by using Set Associations.
      1. Open Default Programs by clicking the Start button, and then clicking Default Programs.
      2. Click Associate a file type or protocol with a program.
      3. Click the file type or protocol that you want the program to act as the default for.
      4. Click Change program.
      5. Click the program that you want to use as the default for the file type you selected, or click the arrow next to
      Other Programs to show additional programs. (If you don't see Other Programs, or your program
      is not listed,
      click Browse to find the program you want to use, and then click Open
      6. Click OK
        So, I lost my .rvt file association broke somehow when I upgraded to 2016. No big deal, I just reassociated it with Revit.exe. The problem is, it opens a new revit every time I double click a file in the explorer. My assumption is that there is something similar the the "dwglauncher" in AutoCAD. Anyone know what program should be set as the default program?
