An Issue with inserting a window
    Hi, I have been having this issue in Revit for a little bit now. Sometimes when I insert a window it shows the window properly cutting through the wall in plan view and then the next time I insert a window I can see the wall through the window component. In elevation the window looks fine. I have attached a picture showing the two instances. The one at the top is show correctly and the one below is not. What can I do to fix this problem.
    Is it a high window in the bathroom? It may be above the cut plane for the view. If so, define a Plan Region and define a new cut plane height.
