Convert Project Parameter to Shared Parameter
This topic is closed.
    I know with the Extensions you can convert familiy parameters to shared parameters but I would like to do this with project parameters. Does anyone know if that is possible at this time?
    Rustle
    Rustle
    I was looking for this same thing the other day and was to no avail. I do not believe this is possible at this time.
      Hi guys,
      there's a way to achieve this. first you should have already a shared parameter file related to your project.
      Go to Manage>project parameters. Select the parameter and then Modify.
      Select in the window Export. get an info message then OK.
      Go to shared parameters, you have now a new group named Exported parameters.
      Select the parameter you've just exported, then Move.
      Select now the group of the other shared parameters. You're done.:wine:
      Your exported parameter is available in other projects as a shared one.
      Let me know if you have problems.
      See below please......
      Julien
      P. DAC
        When I go to do this "Export" is grayed out so I cannot select to export...am I missing something?
          Checking.............................
          So, my fault my very fault, what I explained was in fact a way to keep already SHARED parameter when the .txt file is missing.( I did it a little too fast......it's bed time for me now!)
          Sorry guys, no way to transfer Project parameter to Shared one.(for now, I will test something at work tomorrow).
          But there always a way to transfer Project parameter to another one with Transfer Project Standards
          see you
          Julien
          P. DAC
            As far as I know, it can't be done...
