Room Tags in a Large, Referenced Project
    I'm quite new to Revit and I've been tasked to put together a code compliance schedule (room areas and occupant loads) for a large project which has been modeled in 3 individual building files and referenced together in 1 site model. Is this something I should do individually per building file or is this something I should do in the combined file? It seems better to do this in the individual files so that the room numbers appear in the original files for personal reference sake, but it seems that the room tags don't get referenced with the building files into the site file. It would make sense though, too, to create the tags in the site file so that the room numbers remain unique among the different buildings.
    Any suggestions?
    Thanks!
    Check this out:
    http://www.saubim.com/
    Also, I believe that in RAC 2012 you can tag Rooms across Linked files.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Thanks, but I don't have the opportunity to purchase software. I've found a way to get the schedule to calculate what I need, I'm just looking for the best way to go about the room tags (what problems arise when tagging in original files vs. problems when tagging in a referenced file).
      Thanks.
        FWIW---The software is only $20.....................
        but I understand what you are asking.
        The answer is, there is no perfect answer!
        You have to just get into the project and try tagging across links, scheduling across links, and see how it goes.
        The old learn by doing method actually is one of the best.
        good luck.
        Cliff B. Collins
          If the Phases are mapped correctly, you can tag the Rooms in the Linked File. Or, go in to the old file, Tag the rooms in a specific View, then in the Parent file set the VG: RVT Link to By Linked View: The view in the link that has the room tags. So its tag across links, or tag in links. Both methods work, both will do what you want. Its either the inconvenience of By Linked View and not being able to move room tags easily, or the inconvenience of your tags versus room elements being in two different files, and having to move back and forth to change tag data.
          Either way, you wont be able to change room names or numbers without going in the link, so bear that in mind.
          As for the Link... You can do all of it with Key schedules and calculated values, for free.
            Since this is a large project, you may be best off using Aaron's second method - setting the Link Visibility to a specific View.
            The reason being - even though you can now Tag a Room through a Link, as far as I can tell, the Tag All does NOT work through the Link.
            So you have to place each Room Tag one by one in your Site model.
            Dave Plumb
            BWBR Architects; St Paul, MN
              Does that mean I'd have to link each floor (sheet view) as opposed just linking the file once?
                Absolutely NOT! That is an ACA/ADT Autocad mentality. Views are snapshots of the model, which are then placed on Sheets.
                Revit links should be entire MODELS--not slices of floors like we used to do in ADT.
                By Linked View is doable, but pretty hard for all users to grasp and for the team leader to enforce.
                We generally annotate in one model. But there are occasions when annotating a linked file works better. My advice is:
                Try out both ways and see how the team responds, make a group decision and move on.
                Cliff B. Collins
                  You do NOT need to Link the other models in multiple times.
                  What you will need to do is set up each VIEW in your Site model to point specifically to a View in each individual building model.
                  Last edited by DaveP; August 2, 2011, 06:17 PM. Reason: Looks like Cliff pretty much said what I was about to.
                  Dave Plumb
                    Oh, great!
                    I've done that with one level, but it still isn't recognizing the room in the schedule. And if I try to just create a new room tag on the reference it fails to recognize a "properly enclosed region." Shouldn't it recognize the walls/boundaries if this is a BIM as opposed to a "dumb" reference?
