I was having an issue ages ago with my toolbars jumping around with each click. I recall finding a solution and now longer have any issues. But now one of my collegues has the same issue and now I cannot refind the fix. (Pretty sure it was on some other forum ). It had to do with the way toolbars were docked I think. I am pretty sure it also has to do with the graphics card. Does anyone remember how to solve this?
Browse Autodesk resources to find product documentation and troubleshooting articles to resolve issues. Subscribers can also contact a support agent.
The common other symptom are small dialogs with only the X visible to close the dialog. Graphics card management software can interfere with the ribbon panels, making some dialogs small and cause others to not display. Please let us know if this appears to be the case.
I had not tried the 'dock to bottom' option, though it seems to get rid of the jump. I don't like my tool/command options being so far from the ribbon though. I'm even less likely to notice when there's a little checkbox for 'Delete Inner Segment', etc.
So, for the record, the last option I listed worked well. I'd still recommend copying/backing up any files before modifying.
Hope that helps,
-josh
FOLLOW UP: Just fixed this issue by exporting Autodesk and subfolders in REGEDIT (see link above); then I selectively deleted the entries under Revit/Autodesk Revit Arch.../Profiles. I left AllAnavDialogs and OpenSaveAnavDialogs. This did the trick and stopped the jumping tool bars. All of this was done in Windows 7 (64 bit) and with a Revit Architecture 2010.
I'm a beginner and just discovered that you can right click on any tool button on any ribbon and it allows you to add that command to the QAT (Quick Access...
We experienced some downtime yesterday, and until I woke up this morning.
The hosting company has made some changes to the...
September 17, 2019, 06:42 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
