Shaky File
    Shaky File
    I have a file that has started to act funny. Bathtube and washing machines are the same type of fixture, filters are effecting other type of items, etc. Is there a procedure to correct file problems in Revit? In acad you would "replace the files header".
    Need a bit more specific information--but you can try:
    1. When opening the Central File, click Audit.
    2. Review all Warnings / error messages.
    3. Purge Unused families--sometimes a corrupt family will cause unexpected behavior.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      uhhmmm, this is a bit vague. Could you be more clearer? Or post the file and point us into the right direction?
        While you're at it: What the heck is "replace the files header"?
        I've done AutoCAD support for 20 years & never heard of that.
        Last edited by DaveP; August 1, 2011, 07:04 PM. Reason: Not that I really care, though.
        Dave Plumb
        BWBR Architects; St Paul, MN
          I think he means actually go into the DWG file with a text editor and replace the header portion of the file contents. I've never heard of it either, but am curious to know how it works.
          Just for fun I opened a DWG in a text editor. Pretty scary stuff.
