Sheet Index discipline attribute not pulling from linked files
    I'm setting up a sheet index with links from our files and a few other firms. It's pretty straight forward - Sheet Discipline, Sheet Number, Name, and then a number designation for sorting. For some reason the Sheet Discipline field is the only one that is not populating from the linked architectural models. I have checked the Sheet discipline parameter in my file and the architect file and they appear to be identical. All other files are populating the sheet index without any issue. Any ideas as to what would be causing this?
    Thanks!
    Did you both use the same Shared Parameter from the same Shared Parameter File, for Sheet Discipline? If not, theirs won't populate your schedule.
