mount face based family onto underside of slab
    what is the best way to mount face based family onto underside of slab? well, i used to do it in 3D, but not easy to control location, etc.
    Just thinking out loud here....Create a level under it, then use that as an underlay set to reflective ceiling plan?
    Dan
      this is workaround just like using ref plane, but what if i actually want to host to underside of the slab?
        Place the family from the ceiling plan view that corresponds to that slab.
          right, i can tab select that slab, at first i thought i can only select ceiling.
          as usual, Alfredo came to rescue! thanks Alfredo and have great weekends!
            Hey, I helped!! :laugh:
            Dan
