I have a multi story and I'd like to setup a view template to cover all the plan views. I set my view range to: top = level above, offset 6"; bottom = associated level.
My question is on the top floor, there is no level above. Does Revit know what I want or do I need a separate view template for the top floor?
I'm curious why you've used a 6" offset beyond the Level Above?
When there is no level above then there is no practical difference between Level Above and Unlimited except that there is an offset value available to the Level Above setting. This means you can still restrict the Primary Range above your current level via the Offset value...but then your model probably doesn't contain anything relevant very far above the last level anyway. Unless something well above the model also crosses through the view's cut plane it won't be visible ordinarily anyway.
I usually use a level for roof as well...just interested in how Revit reacts to forced conditions that don't exist.
Yes, it is pretty common to do so. The View Range is usually adjusted to move the cut plane well above the roof so it creates a view that looks like a roof plan should. More often than not the level is actually marking the Top Plate elevation for wood framed structure or Top of Steel for a wood/steel framed flat roof.
Still working on my view templates. Would I be working too hard if I set a view template for each floor?
I'm looking at 4th floor deck penetrations. In order to get the correct walls to show up, I need the arch link to be set to Level 4. This kills all my work of trying to have a single view-template.
Sheet types: Plan Views, Deck Inserts, Deck Penetrations. Math. 4 floors x 3 Sheet Types = 12 view templates?
OK, I think I am not seeing the forest for the trees so to speak. I have a project I am doing an as-built for. It is truly basic...2 stories, so 2 levels....
I have a FCU that is placed on level 1 ref. level and is showing on level 2 floor plans. My view range isn't set to go below associated level, I dont...
It is written in the manual that on element in the main range (from top level to the bottom level) is drawn with the projection line.
But to me...
June 20, 2013, 11:37 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
