Divided parts
    Divided parts
    Hey
    I have a problem when i have divided a wall.
    I wish to align the parts i different heights in a section, but it tells me that it is not possible.
    is there a tutorial i can can use?
    Help please
    check here:
    http://docs.autodesk.com/subscriptio...f7abe-7f7e.htm
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Hi bjarke78; welcome here in RFO.
      if you're playing Parts (2012 feature), you'll find a tutorial here.
      the above link deals with modifying layers in a wall, nothing to do with Parts.
      To adjust Parts height, you select the Parts, check option "show shape handles" and then stretch layers you need. Align tool works.
      Julien
      P. DAC
        Yes--we need clarification about whether you are using a basic compound wall, and need to adjust the individual components up/down,
        or--if using 2012 and Parts/Assemblies. Good comment by Julien.
        Cliff B. Collins
