View title
    View title
    I have a modified view title that I have used in multiple projects. In all of my projects (except one!) the view title shows up as a circle and extension line with a lineweight of 1. I have one project where it shows up printing like a lineweight 5.
    I've checked the family in the offending model file for the following:
    1) The family of the view title on the sheet has the lineweight set to 1.
    2) I've checked the VG and Object Styles to see if view titles have a lineweight set incorrectly; nope.
    3) I've re-imported the view title family (just to make sure) and I've checked the view title family in other projects (even re-imported the same view title to make sure it had not changed).
    Any ideas? It is just kinda driving me buggy that in this one project the view title shows up drawn with heavy lines.
    Any help for this nitpicky complaint would be appreciated
    Have you checked the VG overrides?
    Dan
      Yep, see item 2 in first post. If you go to Visibility Graphics while on a sheet view, "view titles" is grayed out as an option to override.
      I also checked the Object Styles to make sure it is set to lineweight 1 and it is.
      When I picked the view title in the sheet view and try to "Override graphics in view", all the options were grayed out....
      Wait a minute....I tried that again just now and it lets me select the "element".....sure enough, set to lineweight 7 (I am sure I did that 5-6 times already and always got grayed out options!).
      Hey, thanks a lot
        Woo Hoo! I got one right. :laugh:
        Dan
