Parameter Jerk (free Add-in) - Released!
    I've released the beta version of Parameter Jerk 2012.
    It works in both Revit 2011 and Revit 2012.
    Parameter Jerk helps to automate importing of one or more shared parameters into one or more Revit Family Files.
    Supplemental data (defaults) can be attached to each parameter indicating where to "Group Parameter Under", whether it's an instance or not and a there's a notes field.
    oh...and it's free....'cause that's the way I roll.
    Try it out, let me know what you think, ideas for improvements, etc. Feedback
    ps...i can't seem to upload a screen shot but keep getting the red explanation point. Que pasa?
    ...gregory
    mertens3d - 3d architectural rendering
    hatch22
    here's a screen shot
    ...gregory
    hatch22
      Looks great Gregory, downloading now can't wait to try it. Thanks
      Mark Balsom
        'b' version posted. I forgot to include some xml parameters for Revit 2012
        ...gregory
        hatch22
          Gregory, what more can I say except BRILLIANT what a valuable time saving addin, once again brilliant , well done and thanks.:thumbsup:
          BTW The b version fixed the other issue.
          Mark Balsom
            Wow! sorry I have to wait the end of vacation to try it!
            There's an extension that is supposed to do the same no? but far far away from handy AFAIK.
            thanks for sharing, maybe it could be add to the RFO addins?
            Julien
            P. DAC
              Yeah...you have to kind of laugh (or I do, at myself). Just after I finished the routine I did a search for something similar and came across "Revit 2011 Shared Parameters Converter Extension". It does do something similar but with a couple major differences.
              1) it does not allow you save/ restore configurations which would make it difficult to use on the fly. i.e. when productions staff download a family from the web.
              2) it does not allow you to apply to the current file.
              But...still. I suppose a major reason for me to write it was for the learning experience.
              ...gregory
              hatch22
                Gregory, no laugh at all. Your stuff is REALLY handy compares to Autodesk stuff.
                I will try it in real production mode in a few weeks, will send you some feedback then.
                First things, re sizable window maybe; and the ability to set a default value to the parameter?
                thanks again for sharing it with us.
                Julien
                P. DAC
                  Julien,
                  I have added your suggestions to my to do list. Default values meshes up with an existing one (formulas, add order)
                  ...gregory
                  hatch22
