Wrong User Name?
    Wrong User Name?
    how to get around this issue without having to change my user name? :banghead:
    Why won't you change the user name? Can you create a new localfile from central?
    Sent from my HTC Sensation using Tapatalk
      can't create a local file but it does work using "Detach from Central"...
        Detach from central, save as and it will create a new local and central file...
          Why are you trying to open someone else's local file anyway? Unless your just trying to get info from it, then detach from central is your only option...
            I think it's trying to tell you to stop working and go play a round of golf. :thumbsup:
            Dan
              worked a treat, thanks!
              because that's what the Architect sent me to replace their old Revit model so I can link it into my project. It took me 2 weeks to get this model and I didn't want to go through the process again.
              I like your style Dan
                They sent the local file? wow....
                Yep...just open, detach, and resave....
