What does this do???
    Ok, here's something weird...
    I am working on a project and need to schedule certain parameters (Yes/No) to a Room. The parameter only applies to Rooms which have a certain feature:
    If room A posesses feature X I want to be able to choose between option 1 or 2. Here's what I did:
    1. Create a Room Schedule.
    2. Create filter for feature X. Only Rooms which have feature X are filtered.
    3. Create a Yes/No parameter. Yes means Option A, No means option B.
    So far, so good. Now it get's complicated:
    I was looking for a way to NOT have the Option A/B parameter show up with all Rooms. I noticed a checkbox when applying a shared parameter which reads "Add to all elements in the selected categories" (fig 1). So I figured, if I uncheck this, it might just apply to ONLY the elements in my schedule.
    But this checkbox deselects all Categories. The Yes/No parameter is no longer accesible. Not in the Room Properties, not in my schedule (fig. 2)
    My question is: does anyone have any clue what this parameter does???
    my guess is that you applied the change, to the selected item only, so if you find the room you had selected at the time, the option is still there, but not in any other rooms.
      No, that's just it. It doesn't affect anything. The parameter doesn't even show up in the room properties. Besides that, I'm adding it in the schedule so not really related to any room at all. Might that be the problem? But I can't add a parameter to an object in the project environment, so why is it there?
      I'm getting really
        That is a very intriguing option. If it is checked, supposedly, it "adds the parameter to all the categories selected", but if it is unchecked, it just unselects everything, so you cannot choose the category to which you want to apply the shared parameter. I had never noticed this setting before, and I don't understand how it works either.
          Any Autodesk staff want to comment??
            You didn't make the parameter type based for a room did you dude?
              The same question has been asked before: http://forums.augi.com/showthread.php?t=84701
              Looks like to leave that option be.
              Arjan Ikink, BIM-engineer at PHB Deventer
              LinkedIn
                Nope, that option isn't available when adding parameters through a schedule.
                  Right, this solved the mystery of what it does...
                  But that's the point, it doesn't seem to work with rooms. I don't even get a single room with this value (which would be tremendously cool btw)
                  More testing here...
