2011: Should the ambient occlusion pass show up in plots?
I've got several views that are set to shaded-with-edges and have ambient occlusion turned on. When I plot these views, either directly to the plotter or to PDF files, the ambient occlusion effect does not show up.
Is this just something weird with my setup or is this a "feature"?
Julien, exporting indeed does sometimes work (on smaller sizes). But that wasn't the question: will it PRINT? The answer to that question is no, it won't. You can't print AO to pdf or directly on plotter. The only workaround is creating an image by export and reimporting this. Also you can save a view as an image from within revit and place this on a sheet. This should work also. (again, only for sizes smaller than 2000 pixel).
1. Any updates on this 2000 pixel limit on ambient occlusion export ? Does it still apply ?
2. Is there a 'live' work-around the export image method ? Once the image is exported, it is 'dead', any way to have an image that will update itself without the user needing to re-export and re-insert into sheets every time ?
I am trying to print some sample PDF's of the families I created. I also created a titleblock. For some reason the 3D view takes an excruciating long...
When I print to pdf one of my sheet views it comes out different to what is shown, for instances all my Arch' is greyish but when PDFs the walls are showing...
anyone having trouble when plotting with scale and paper orientation, the drawing sheet has too large of a margin around and paper rotates when plotting...
October 28, 2014, 02:56 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
