So I'm confused, casework is meant to be a cuttable category right? Well it isn't working for me - unless I'm missing something, or changes were made to their VG behaviour in releases after 2008 (the only version I have access to at the moment at home).
Attached is a model I've been testing with, that features quick test families made straight from their respective templates of casework, furniture and generic models. As you'll see, (if you open it) when placed directly, only generic model (both shared and unshared versions) are cut by the plan region, which aligns to THIS - but they only cut when nested (in a casework host family here) if they are shared.
The thing I don't get is how this common suggested "workaround" can be followed through in a practical workflow - having to use a "container" family for scheduling seems a bit unwiedly - moreso when you realise you can't associate parameters (for said schedules) between the host casework/furniture family because the nested generic model is/has to be shared for the plan regions to work!?!! :banghead:
Anyone found a nicer workflow for detailing furniture/casework elements?
