Bringing Hidden Objects Back.
    When I right click an object and click on hide object in view.
    How do I bring that object back?
    Type "RH" to reveal hidden objects. If that doesn't work, click the little light bulb at the bottom left of your view (does the same thing). The hidden object will be highlighted in a fuscia color. Select it and click "Unhide Object" in the contextual ribbon.
    Suggestion for future, if you just want to temporarily hide the object, select the object and type "HH". This will hide the object and put a cyan border around your canvas, meaning there are objects temporarily hidden. These objects will print and will reappear if you use "HR" (Reset Hidden Objects) or if you close the project and reopen it again (ie: it's not a permanent hide).
    If you decide you DO like it hidden and want to make it permanent, you can bind the keystroke "AH" to Apply Temporary Hidden (also available via the sunglasses bottom left of canvas). When you do this the cyan border will go away, the hidden objects will not print, and closing the project will not cause them to reappear.
    HTH
      cool thanks
