Cobie data input
    Cobie data input
    Hi Guys,
    Im just newbie here in this forum. I want to know how the Cobei extension works in the project. Is the component parameters to be input manually inside Revit under Cobie requirements?
    Example> room tag, gross and net area are not filled up automatically?
    cheers
    Did you get the extension from CADD Microsystems at COBie Extension Download | CADD Microsystems ?
    They have a contact address:
    Kamran
    Kamran Mirza
      I already installed the plugin. What I want to know if I manually input the parameters of the component on the properties under Cobie rows as shown on the attached image above.
      cheer
      s
        Originally posted by fjtdogeno View Post
        Hi Guys,
        [ATTACH=CONFIG]24321[/ATTACH]
        cheers
        I am currently looking into COBie and have had the same issue. I assumed that when the add-in creates these new parameters and I place an air terminal. The COBie.Space.Name parameter for the Air Terminal would be automatically populated.
        So I’m also looking for clarity to if this information should be done manually.
        Domsib
        Revit MEP - 1 Day at a time...
