Satir riser go missing
    Hi all,
    Please see attached picture. I have created these stairs by sketch, I then modified the boundaries to create the L-shape, after doing that the risers disappear, has anyone had this same problem? It should be a solid concrete stair.
    Thanks
    Lox
    I have this happen on monolithic stairs too. switch the stair to a pan stair and it will be fine, doesn't solve your problem, but shows the bug
    So What I do is make a modified Non monolithic stair type with a very thick tread and no riser.
      Hi all,
      The best solution for me is to use the monolithic stair with a run that has been modified the Underside Surface Parameter to Stepped, then you get a fine result,( See the attached images).
