Exporting DWG with NCS/AIA Layernames but from UK Metric
    Hi, I have UK Metric installed but I need to export DWG drawings with the NCS/AIA layernames.... How do I go about it, I can't find an option button / pulldown menu to change the export settings from the ones that come with UK Metric. Thanks for help in advance. Kamran
    Kamran Mirza
    Click on the Application button, Export, scroll down to Options, pick Export Setups DWG/DXF, then pick the standard you want to use from the "Load layers from standards:" pulldown list. This is for RAC 2012. RAC 2011 has a different dialog box setup, but the procedure to get there is the same.
      Thanks J, found it and got the standards. Many thanks, Kamran.
      Kamran Mirza
