Group Parameter
    Group Parameter
    Just a newbie and need some help.
    Is it possible to add a new entry or new group parameter in Parameter Properties (Group parameter under?
    Kindly refer to attached snapshot.
    Thank you very much!
    Best regards,
    Jervin A.
    hi Jervin, and welcome to RFO !
    Have a look here:
    Create Shared Parameter Files, Groups, and Parameters | Revit Products | Autodesk Knowledge Network
    It says:
    "Add groups:
    In the Groups box, click New.
    Enter a name for the parameter group, and click OK."
    You can make a new group when you make a new parameter, I guess, haven't done it before.
    Kamran.
    Kamran Mirza
      Yes, welcome to RFO.
      I believe though that the OP was asking if they could create a new parameter group -- as it would be displayed in the properties dialog box. As far as i know, this can't be done. This is hard coded by the programmers.
