How to print that all lines would be thick lines?
    Title of thread says everything :coffee:
    Well, Override graphics in view, set all categories to thick linestyle. Revit prints everything in Thick Linestyle, but you won't notice that when you have all Object Styles set to a thin style.
      I was hoping for some kind of function like " print all lines in thin lines". So i have to make manually in Override graphics in view, then in object styles.
      When i change in object styles, is there any DEFAULT function, or save settings as? because if i set line weight to 1, hit save. Previous settings will disappear.
        You could create View Templates for this and Override by Category in that specific template. That would pretty much give you a "magic button".
          Why? What effect are you trying to get that you have no lineweight differentiation? Perhaps there's a better solution than just overriding all the lineweights...
          Arcturis
          BIM Manager
          Associate Architect
            Just colleague of mine asked me this, he wanted to print in pretty big scale with thin lines.
