Inclined curtain walls
    How do i set the walls on an inclined plane,not vertical...is there any chance to create them? Do I have to use a mass? Thanks in advance
    Create a mass and inside of the massing toolbar there is an option to place a wall by mass use that!
    We have a video for it at www.archdesignlabs.com if its confusing still.
    Adam
    J. Adam Thomas
    Owner - www.archdesignlabs.com
      Done. But it tells me that "Wall type 'Curtain Wall 1' is incompatible with picked face. Only basic wall types are accepted."
      The face that i've picked is not slanted,but curved, and i want to create a curtain wall on it. Can u give a little more help please?..
        Well if its curved that is completely different. You cant say slanted if you mean curved haha. Try using Exterior Glazing or Storefront and see if the issue still exists. I have done plenty of walls like this so I know its possible it just all depends on how its modeled and what it looks like. You can also tell the structure of a basic wall to be glass as a work around. Attach a picture?
        J. Adam Thomas
          Well...they are curved in elevation). The attachment will show. So i have this mass, and i want to attach a curtain wall to its side.
          And i also have a problem with that blue line,i can't get it out,hope my "paint lateral view" helps. Thank you
            Create the shape as a conceptual mass instead then load that into the project you are using an in place mass currently it looks like.
            J. Adam Thomas
              I think it will work with curtain systems
                Create a generic model of required shape and add curtain system to it. .
                It works. . .
                  Oh dang. I just realized that I didnt write curtain system. In my head and on my computer I was doing it but was saying the wrong way. Very sorry.
                  J. Adam Thomas
                    I have not used RAC in a few years, but back then they had "Sloped Glazing" as a choice when creating curtain systems...do you not need to use this?
