How to Extend a Room Over Walls
    How do you extend a room over partition walls, for example when you have cubicle partitions within a larger washroom but the partitions are made of solid masonry walls. (I'd like the room called 'WC' to extend into the cubicles). Example attached as an image. Thanks.
    Kamran
    Kamran Mirza
    You can select a wall and uncheck "room bounding" in the properties pallette.
      Great, thank you very much. Kamran
      Kamran Mirza
