Revit 2012: 3D View on sheet
    Hi all !
    2012 have problem with rotation 3d view after add on sheet.
    if you rotate the view after the placement on the sheet, it reverts after rebooting the project !
    update does not fix the problem :banghead:
    any ideas ?! ...
    Regards,
    Nikita
    BIM&Architecture
    Try this:
    On the View Cube, right click and select "Save View".
    see attached.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      OK, it's work
      Thanks!
      But now need "Save view" every time after rotate
      and how to deal with the perspective view? they do not have the cube
      Regards,
      Nikita
      BIM&Architecture
        You can use Save View in camera/perspective views also.
        see attached.
        Cliff B. Collins
          Also look to the View Control Bar at the bottom of the Revit window....new tool for 2012 is save Orientation and Lock View. that should do the trick
          Scott D Davis
          Sr. AEC Technical Specialist
          Autodesk, Inc.
          http://bit.ly/aboutsdd
            Good tip Scott!
            Cliff B. Collins
              "Save view" work. But this create a new view every time.
              "Save Orientation" and "Lock view" not fix this problem.
              Regards,
              Nikita
              BIM&Architecture
