Change line color of linked columns
    I'm currently working in a structural model, i'm linking in the architectural model and I wish to make their columns appear with a red lineweight.
    The problem is when I go into revit links--->arch model ---> custom and then change the line to red nothing happens to the linked model. I'm sure it's something easy but right now it's driving me bonkers. Many thanks in advance.
    Are you changing the color of the cut line? Are you sure they have modeled columns? Are the columns they are using set to be visible in plan or is it only a nested detail component?
    Julie Kidder
    Architect + BIM Director
      Or are the column extrusions on a subcategory of columns? You can also use a filter which will work through a link.
      Brian Mackey |BD Mackey Consulting
      www.bdmackeyconsulting.com/blog
      @Twitter
        thanks for your help guys,
        I figured it out. The columns in the architectural model were under 'structural columns' not 'columns'. rookie mistake...
