pipes not visible in floor plan view
    i have a pipe that is visible in section and 3D view but not in floor plan view.
    i have checked the view range, no filters applied to the pipe. May i know what is the problem?
    Pipe above your cut plan? Pipe below a floor?
      My first step in troubleshooting visibility in a view.
      Go to a default 3D view. Right click the view cube>orient to view>floor plan>view in question
      This will orient your 3D to the same bounds as your plan view with the scope box set to the View Range of the view and Visibility Graphics set the same.
      This will often show why the object is missing.
      I used to be high on life, until I realised it was cut with Morons.
      Combating ignorance daily through learning.
        Try changing the Discipline from Coordination to Plumbing. It solved it for me!
          Check view detail setting is set to fine, shows detail item not symbolic line.
          Steve
