missing curtain panels
    Ok, stupid question that I should know the answer to:
    I'm working on a curtain wall (I did not create it, someone else did), and there are missing curtain panels. Not System:Empty panels, but the panels just aren't there. Other than deleting the wall and recreating, is there some way to add panels back?
    are some missing and some there or all missing? If it's just some missing I would guess Hidden in View or with a filter. Have you tried Reveal Hidden Elements?
      Some are missing...and I've tried revealing to no avail. They don't exist in the model.
        and the missing curtain panels are in the same curtain wall that has curtain panels? You can't delete an OOTB curtain panel from a curtain wall to my knowledge so something weird is going on for sure. I'm going to have to see if a custom curtain panel family can be deleted, never tried it before.
        edit: nope, can't delete a custom panel either. Any chance of getting a copy of this curtain wall?
          I just deleted it and made a new wall.
            dang! you should have saved it for the Revit museum of weird happenings!
              Do you have worksets on? Could someone have accidentally set the panel to a closed workset?
                I see you deleted and started over but I work with curtain walls and I have had this issue.
                Usually if you get to the edge of where the panel should be and tab the empty area will stil highlight and you can change it in the properties area.
                I also check to see if the profile shape is correct? I have found sometimes resetting the profile fixes these kind of issues for me.
                  me too! Terrell, TX = Oldcastle??
                  edit: oh, and welcome to the forum!!
                    Yes OldCaslteBE. Im only 7 months here, they are implementing Revit into their bidding process.
