I can't control dimensions on a opening wall
    Hello!!!
    I have a Wall that have an irregular shape and I am trying to cut a regular opening, but when I have cutted the opening I can't control the dimensions of the opening.
    I make other regular opening in other walls that have regular shape and I don`t have any problem.
    Does someone knows what's going on?
    Can you post the example file?
    I'm not sure what you mean by an irregular shape? If I edit the profile of a wall, I have wall openings act as expected...
    I used to be high on life, until I realised it was cut with Morons.
    Combating ignorance daily through learning.
