Installation Error
    Installation Error
    Hi everyone
    First of all, I'm sorry if the topic is irrelevant to this category and if it belongs anywhere may the admins move it please.
    Now, back to the subject. I had to format my computer and I installed a fresh Revit 2014, so I installed the program and everything was fine, I also managed to work a bit last night. This tonight I opened Revit again and I was receiving a message about expired license, etc.
    So I uninstalled Revit (got few errors during uninstallation and I had to use a third party uninstaller) and now during installation I'm getting two errors and the installation is automatically cancelled. I've attached the two images and the last few line of the log file. If the whole log file is required just let me know.
    So after reading the log file, I though the error would be solved by installing DirectX, I did download the final version and install it but I got the same error again.
    2015/4/27:19:52:49 Greg GREG-PC === Setup started on GREG-PC by Greg ===
    2015/4/27:19:52:49 Greg GREG-PC Path_Length: 149
    2015/4/27:19:52:49 Greg GREG-PC Current Directory C:\Users\Greg\AppData\Local\Temp\_AI7CBE.tmp
    2015/4/27:19:52:49 Greg GREG-PC Launch
    2015/4/27:19:52:49 Greg GREG-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Greg\AppData\Local\Temp\_AI7CBE .tmp\Setup\RevitSetup.dll
    2015/4/27:19:52:49 Greg GREG-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
    2015/4/27:19:52:51 Greg GREG-PC PageOpen LaunchDialog
    2015/4/27:19:52:55 Greg GREG-PC PageOpen LicenseDialog
    2015/4/27:19:52:57 Greg GREG-PC PageOpen ProductInfoDialog
    2015/4/27:19:54:40 Greg GREG-PC PageOpen ProductSelectionDialog2
    2015/4/27:19:55:40 Greg GREG-PC PageOpen FullProgressDialog
    2015/4/27:19:55:40 Greg GREG-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86. exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Greg\AppData\Local\Temp\vcredist_x86_2005 .log"" "
    2015/4/27:19:55:50 Greg GREG-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
    2015/4/27:19:55:50 Greg GREG-PC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
    2015/4/27:19:56:06 Greg GREG-PC Install DirectX® Runtime Succeeded
    2015/4/27:19:56:07 Greg GREG-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\Autodesk_Revit_2014_Englis h_Win_32-64bit_dlm\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Greg\AppData\Local \Temp\_AI7CBE.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_ English_Win_32-64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2015/4/27:20:15:26 Greg GREG-PC Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
    2015/4/27:20:15:26 Greg GREG-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    2015/4/27:20:15:26 Greg GREG-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
    Did you already try uninstalling Visual C++? Because you probably did all your Winupdates first, a newer version was probably installed.
      No I didn't try that. I will tonight and will report back
        Just tried it now. I'm getting exactly the same two error messages and the installation then stops.
        2015/4/28:19:13:43 Greg GREG-PC === Setup started on GREG-PC by Greg ===
        2015/4/28:19:13:43 Greg GREG-PC Path_Length: 149
        2015/4/28:19:13:43 Greg GREG-PC Current Directory C:\Users\Greg\AppData\Local\Temp\_AI11EA.tmp
        2015/4/28:19:13:43 Greg GREG-PC Launch
        2015/4/28:19:13:43 Greg GREG-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Greg\AppData\Local\Temp\_AI11EA .tmp\Setup\RevitSetup.dll
        2015/4/28:19:13:43 Greg GREG-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
        2015/4/28:19:13:45 Greg GREG-PC PageOpen LaunchDialog
        2015/4/28:19:13:46 Greg GREG-PC PageOpen LicenseDialog
        2015/4/28:19:13:51 Greg GREG-PC PageOpen ProductInfoDialog
        2015/4/28:19:15:35 Greg GREG-PC PageOpen ProductSelectionDialog2
        2015/4/28:19:16:12 Greg GREG-PC PageOpen FullProgressDialog
        2015/4/28:19:16:13 Greg GREG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x 64.exe" /q
        2015/4/28:19:16:20 Greg GREG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
        2015/4/28:19:16:20 Greg GREG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcred ist_x64.exe" /q
        2015/4/28:19:16:27 Greg GREG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
        2015/4/28:19:16:27 Greg GREG-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86. exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Greg\AppData\Local\Temp\vcredist_x86_2005 .log"" "
        2015/4/28:19:16:34 Greg GREG-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
        2015/4/28:19:16:34 Greg GREG-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64. exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Greg\AppData\Local\Temp\vcredist_x64_2005 .log"" "
        2015/4/28:19:16:40 Greg GREG-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
        2015/4/28:19:16:40 Greg GREG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x 86.exe" /q
        2015/4/28:19:16:45 Greg GREG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
        2015/4/28:19:16:45 Greg GREG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcred ist_x86.exe" /q
        2015/4/28:19:16:52 Greg GREG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
        2015/4/28:19:16:52 Greg GREG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x 86.exe" /q /norestart
        2015/4/28:19:16:58 Greg GREG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
        2015/4/28:19:16:58 Greg GREG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x 64.exe" /q /norestart
        2015/4/28:19:17:05 Greg GREG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
        2015/4/28:19:17:05 Greg GREG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredis t_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Greg\AppData\Local\Temp\vcredist_x86_2005 .log"" "
        2015/4/28:19:17:14 Greg GREG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
        2015/4/28:19:17:14 Greg GREG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredis t_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Greg\AppData\Local\Temp\vcredist_x64_2005 .log"" "
        2015/4/28:19:17:20 Greg GREG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
        2015/4/28:19:17:20 Greg GREG-PC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Revit_2014_English_Win_3 2-64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
        2015/4/28:19:17:36 Greg GREG-PC Install DirectX® Runtime Succeeded
        2015/4/28:19:17:36 Greg GREG-PC Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\Autodesk_Revit_2014_Englis h_Win_32-64bit_dlm\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Greg\AppData\Local \Temp\_AI11EA.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2014_ English_Win_32-64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
        2015/4/28:19:29:54 Greg GREG-PC Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
        2015/4/28:19:29:55 Greg GREG-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
        2015/4/28:19:29:55 Greg GREG-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
          I've found the solution. I deleted the "Autodesk" folder in C:\Program Data and the installation worked properly.
            Hi gpktm,
            Glad you got this sorted. I had problems over the past few day installing BDSP 2016. Whilst my problem was similar (was affected by the 2016 version of 360 hanging around preventing AutoCAD 2016 being installed) the solution was similar to yours.
            Here is an Autodesk KB article to help clear out previous installations.
            Be aware that this guidance overs ALL Autodesk programs, but it is easy to reinterpret this for any particular Autodesk product if only one is giving you an issue.
            Sorry I didn't get to you quicker with this, might have saved you some time.
              No worries mate. That would be helpful for anyone who has the same problem in the future.
                I made sure I did the same thing when I reinstalled Revit on my machine....
