divided surface- creating intersects
    Hello!
    I'm new to Revit and am trying to create a custom divided surface grid using intersects, and would greatly appreciate any help as I am ready to pull my hair out!
    The problem is the form is almost like a spiral and I'm having difficulty in figuring out where to place the reference lines that I plan to use as intersects.
    They seem to intersect the entire form rather than a specific target area.
    I'v attached a file that I think will explain my issue a bit better (hopefully!)
    Really really would appreciate the help!
    Thanks a million!
    Niamh
    Welcome to the forum.
    What happens is that some reference planes are intersecting that surface twice, due to the return in the curvature. Also, I see that you want that distance between the blue lines on your sketch to reduce gradually, at every step. That is possible, but it's not simple, and its not possible with a pattern-based grid, but with repeaters and repetitions. It needs a formula to reduce the distance between those "blue lines" along the curve, gradually, in order.
    Search this forum for "progressive spacing", to get an idea.
    Alfredo Medina
    Forum Co-Founder
      One hack would be to break the mass into two different parts.
      I would do that by making the mass and then adding a void to delete one part once and making that as one file. Then do the same for the other part and save that as another file. The pint of cut should be one surface division. Then, I would add surface intersects in each file and bring them together in a new file and join the object at the cut line.
      It is not an elegant solution and requires 4 files to make the mass
      1 original mass
      2 files for the 2 parts with voids.
      1 file for joining the split mass
      however, it is way I discovered that works.
      I did something similar when I wanted to make a surface with part curtain wall and part brick. Check out my website link
      Projects - Lakshya BIM Outsourcing Services
      click on custom modelling
      go to adaptive components and curtain panels
      look for compound facade.
      hope that helps.
        What?
