Revit does not export rendered view
    Hi there guys, my colleague has a problem.
    He left rendering during the night, the render is finished and he cant save image. When he clicks export, sets up desired location etc.. clicks OK and revit immediately jumps back to rendering dialog without saving image.
    RAC2011
    Can he save it to the project ?
      No he cant, he clicks save to Project and nothing happens.
        Sounds like Revit may have dropped the license... can he save the project ?
          Yes he can save the project
            Then it´s not likely to be a licensing problem - What happens if he exits the render dialog, save the project, re-enter the render dialog and choose "Show Rendering", can it be saved then?
            If not, I´d suggest that you file a support request ASAP.
              I'm sorry, but I think he's screwed. I've had this a few times and it probably is a memory issue... I think his work will be lost. What are the specs of the pc?
                Personal Digital Computer
                Win xp
                2gb ram
                ~2.5 ghz celeron
                256mb video card
                400 Gb hdd
                Cant be more specific at the moment
                  I also saw this happen with too few memory. I'm not sure, but I think its recorded in the journals. But it wouldn't help anyway. I also think the work will be lost.
                  [email protected]
                  http://4revit.com
                    2GB is definetly too few for rendering. Only simple tests are possible, crashes and unexpected behavior very common. Even 4GB is not too much for Revit.
                    [email protected]
                    http://4revit.com
