Cut profile line weight
    Where can i adjust line weight for cut profile? In object styles i guess, but where exactly? thanks
    It is hard wired to default line weight 2
    Mark Balsom
      No understand
        This means that you can't change it. It will always have the line weight you assigned to line weight 2 in the line weight table. Same as hatch patterns, which will always have line weight 1
          It is set by line weight 2 and dependent on view scale.
          Try changing line weight 2 in the view scale you are in,change it to say 1.0, set view to thick lines and see what happens to your cut line.
          Be warned this will change evething in your project set to line weight 2 to 1.0.
          Make sure you change it back to your default
          Mark Balsom
            Thanks , now its clear as crystal!
              I do changes in line weight option bar and nothing happens
              hjælp!
                Correct me if I'm wrong but I think you're on the wrong tab and need the annotation line weights. Cut Profile is a 2D override...
                  Well fail.. either model line weights nor annotation line weights doesn't help.
                    The cut profile adopts the line weight of the object it is cutting I think.
                    Not sure it is adjustable on it's own right.
                    Andrew Harp
                    BIM Manager GHD
