Selecting All Masking Regions in Project
    Can anyone clue me into why I can right click, select all instances in project; for Filled Regions but I can't do the same for Masking Regions?
    Is there a fundamental difference between the two except for the fill pattern? Is it that Filled Regions have types and Masking Regions do not?
    Joshua Kohl
    Eastern Exterior Wall Systems, Inc
    www.eews.com
    for this reason, and a few others, I usually use a White Filled Region instead of a masking region.
    Ryan Taube
    BIM Manager - Clayco Construction | Lamar Johnson Collaborative
      Care to elaborate?
      chad
        A filled region with a solid white fill pattern. Used a lot in the early days of Revit before masking regions existed.
          Masking regions were partly developed because a white filled region would export to black in AutoCAD.
          Brian Mackey |BD Mackey Consulting
          www.bdmackeyconsulting.com/blog
          @Twitter
