Wall has odd line, how to delete?
    Hi!
    One of the walls in my building has an odd line going up from it. (see attached picture)
    I can click on it but nothing happens when I click and drag the dots that are placed on the line.
    Does anyone know what this line is, and how I can get rid of it??
    Thanks!!
    mellanslag
    Try to reduce the unconnected height of the wall to just above where you attach it to the roof - could be that the surface pattern thinks it's 4m tall still.
    That he is mad, ’tis true. Tis true, ’tis pity,
    And pity ’tis ’tis true
      You have that wall attached to the roof and the roof is slightly shorter than the wall. That line is the wall extending up and all the dots are the sweeps/voids that are built into the wall. Yes changing the height of the wall as Raff suggests will get rid of the line, but I would look at the roof and see why it is shorter than the wall.
      Brian Mackey |BD Mackey Consulting
      www.bdmackeyconsulting.com/blog
      @Twitter
