5/4 x 6 P.T. Decking
    What is the best way to show the decking on the deck?
    Is there any material that can be applied to the deck floor that looks like the decking P.T. 5/4 x 6?
    Can't you just use a parallel line pattern? (is it ANSI31??) and simply adjust the spacing?? Or are you looking for something a bit more detailed with nail holes and the additional spacing between boards?
      Personaly I would just use a Surface Pattern
      But, if you want to, and its a little over the top, if you look in your OOTB Library Folder/ Sample Files/Fences the is an interesting decking "railing" family. This thing miters bueatifuly, just change the profile to suit your needs.
      also if you really want to model it take a look at beam systems under the Structure tab
      Mark Balsom
        Yeah parallel lines would be fine for 2d but I want to layout the decking in 3d model.
        On this sample file can u be a little more specific about the location please.
          Go to where your default library (families) is kept and look for a the file called Sample Files, in there there are Revit project files loaded with samples of stairs , fences,railings etc. Open the fences file and look for decking, you can select any of these samples and just copy/ paste into your project.
          Mark Balsom
            if you can't find it or don't have it you can download from here.
            Mark Balsom
              Cool thank you.
