Rotate annotations ( see picture ) 180 degrees
    Hello,
    I'm one step further with my annotations but now I try to rotate (mirror) the annotation 180 degrees.
    Is this possible?
    See the picture ( the blue text is OK but the red text I have to rotate ).
    Thanks for your help !
    If you like I can sent you the file so maybe you can rotate it for me.
    No, it stays like this by default. I'm thinking Family for this one...
      Devlin, post the project file you sent me. Others will be able to open it and look at it.
      Come on Martijn, dont give up so easy.
      -Alex Cunningham
        Thanks guys but probably it can't be done.
        Thanks for the effort and time!
          Who said anything about giving up? Only stated that it can't be done using parameters... Here's a GM component which works as desired.
